I'm just resurrecting this item as it has come up again in a current thread (WaveyDavey's mast rotation one)Archive wrote: Bob replied:
Hi Robert,
I suspect that you have to buy the whole ball but speak to Brian Phipps at Windsport. I had it happen to me but as I worked in Engineering I had an apprentice make me up a new one. It has to be a pressed fit & it needs to be domed on top. A half decent approximation is to go to the builders merchants and buy a coach bolt with a domed head that looks about the right size. Buy a few so that you can practice and also have a spare. You then cut off the head with about 15mm of the shank (shaft) left on the head. There is a square section close to the head. Grease it (as it is mild steel and will rust) and fit it in the ball. If it is a loose fit remove it when trailing to stop it falling out. If it is a tight fit then you are lucky so you can hammer it in using a soft drift. It will not come out when the mast is in place as it is trapped. I see no reason why this should not work as a long term cheap solution provided that you keep it greased and keep a spare in case it rusts or falls out when the mast is not on the boat.
This caused my mast to drop down by about 4mm or so (see Steve Willis mast article my one is referred to in that) anyway what had actually happened was that the indentation in the wear plate was actually hiding a hole pushed through the bottom of the mast foot casting by the pin in the mast ball being proud and my preference for a tight rig. I didn't find this until I tried to replace the wear plate and found this hole in the bottom.Archive wrote: Martin Searle replied:
<snip>
I have noticed in the mast's socket there is a piece of metal that has been pop riveted in and on mine this is very worn and the mast step metal insert has left a indentation in it and the pop rivets have been worn almost flat. On comparison with Kevin Dutch's mast which is a pretty new boat there is just a slight worn area on this piece of metal (it looks a lot thicker too!).
<snip>
