Thanks,
Peter
Glad you think £114 is relatively inexpensive Bob, maybe I'll get one block one year and the other the following season. I have a 6 to 1 purchase with the old system so there is a double and a single block at the top, under the hook, but only a double at the bottom to which the end of the mainsheet is tied, over the main block assembly. I let the tiller go and use two hands to tension the main in a blow (hiking out).Bob Carter wrote:Hi guys,
Yes 6 pulleys is standard making a 7:1 purchase system. There are 2 block systems that were sold (ignoring the old Spark Fun which was not a racing format boat)- the old one with 2 stainless steel double blocks plus 2 inner single blocks and the new Dart Special black plastic tripple block arrangement. The later system is by far the best. Several guys with old boats have changed the blocks but kept the lower main sheet pulley/ratchet/cleating assembly. This works well and make the upgrade relatively inexpensive. You can get the blocks from Windsport.
OK Bob, it's worth a punt. Just to confirm, at the bottom I have the mainsheet ratchet assembly with just a double block above it. There are only 6 lines of sheet between the top and bottom block assemblies. I did wonder what all this "Block to Block" stuff was that I heard people talking about. If I buy one more block, then perhaps my arms won't complain so much after a blow.Bob Carter wrote:Hi Robert
Re reading your note I'm not sure I understood it correctly.
If you are a single block short at the bottom you need to get a replacement block to upgrade your system to a 7:1 - you should be able to do this quite cheaply.
