Folks,
All I can say is I got about 100yds off the beach (if that!) and an almighty bang resounded and then it was raining shrouds, trapeeze wires and mast! Was blowing a bit, about F7, and it had just encountered the full breeze for the first time. Bah just put the pesky mast back up after the ODC event Always like the way the mast just gently falls down with the sail attached.
Turned out the two ends of the main hound shackle had splayed apart, first dis-masting I've done on a Sprint for that reason, I've just had the usual shroud breaks before (5 or 6 of those) and once when the bridle wire shackle splayed open in the same way.. Must have had a BIG force on it though or something wasn't quite tight enough.
Pity it was the open day at Seasalter so I provided some entertainment for the onlookers, but one does ones best you know.
