Rob,
Thanks for your kind offer. If nothing turns up in the next couple of months I'll give you a shout.
As a matter of fact I had a really frustrating couple of days - found what sounded like a fantastic sail online but after lots of phone calls it turned out the guy had promised it to someone else... Grrrrrr!
I've pretty much decided that both the windsport and the cat-bitz sails are overpriced. If you add in the cost of battens, then (assuming I had £705, I'd follow Robin's advice re carrots, save up another £75 and get a DX!
Had an interesting discussion with a couple of guys who own a Dart 18 between them, and they reckoned that their sail has been repaired so many times there's hardly any original bits left on it. We had a laugh comparing it to Trigger's broom in "Only Fools & Horses" but it raises an interesting point - how much of a class legal sail (or indeed hull etc...) can be replaced/patched up/repaired before it's deemed no longer legal? Is it even policeable? (I doubt it) and if so, who decides?
George,
Look forward to hearing your plan, but it's the type of courses they lay that's the problem, double upwind sausages etc... etc
I've seen a Laser for sale for £350...
