Hi
At the weekend the little black slug broke off my sail, Questions, should I just ignore it as my older sail did not have a slug,
should I tie the tack to the mast as I did in Phantom,
and my older sail needs some attention in the bolt rope area (worn thin at the batten end where the plastic pockets rub on the mast) Who would you recomend to carry out the repair? Im Oxford based.
Any advice will be appreciated.
Simon 1970
