Bent Mast
Derek James
Bent Mast
Post by Derek James »
Is it possible to remove a slight bend from a single piece mast ? We have a club boat at Draycote with a very gentle bend in the mast . We have tried resting it between two benches and jumping on it but to no effect . Any tips on mast straightening would be appreciated 👍
Javier
Re: Bent Mast
Post by Javier »
I’ve not tried it myself but Joe from Joyrider TV YouTube channel has a video about the topic:
https://youtu.be/4YVQDNdBhYg?si=e0IFq0BJgBKcV7nV
The channel is a gem, by the way.
I hope it helps
Mark Aldridge
Re: Bent Mast
Post by Mark Aldridge »
Probably all you can realistically do Derek is put it between 2 points as the vid' shows and over bend it so it then returns to staight(ish).
Unless it's got a crack in the hound fitting weld which I've seen before. George Carter used to put so much downhaul on he broke them there!
Mark Aldridge
Derek James
Re: Bent Mast
Thanks for suggestions .....the video is great and makes it look so easy ......I suspect Dart masts are a bit stiffer but will give it a go . Cheers Javier and Mark
