Barcelona Maiden Voyage [Dartful Codger 3]
Posted: Sun Mar 17, 2002 8:52 pm
Dartful Codger 3 wrote:
Hi Guys
Christened 1961 today at Beaver in 10-15 knots and was quite pleased with it's performance, particularly up-wind.
However, after packing the boat away, I discovered one rudder blade had taken in a lot of water, whilst the other one hardly had any. On a brief inspection of the blade, I noticed it did not look completely sealed along the back edge where the two halves are joined together, such that you could get your finger nail in at one point.
Without pressure testing it, I'm not sure if it was entering at this point or not, but wondered if anyone else has experienced this problem, or have I just got a Friday afternoon blade which I should ask The Laser Centre to replace ?
In both previous Dart 15's I have owned, I only ever got a small amount of water in the blades when it was a windy day with more turbulent water .
All comments welcome .
Paul Smith
Water in rudder blades [Steve Sawford]
Posted: Sun Mar 24, 2002 9:37 am
Steve Sawford replied:
Paul,
If your blade has gaps in its join ,rep. with gelcoat or send it back.
If your rudder blade has no obvious holes below the waterline, it is getting through the breather hole.
A trick you can use is to plug the hole with a small pice of plastercene.
When the presure expands it will pop out and not damage the
blade,this happens mainly on a hot day in the sail box.
Hope this helps.
Steve (Tiger Shark 1733) www.sailingforall.com
Rudders [Phil]
Posted: Sun Mar 24, 2002 3:40 pm
Phil replied:
Hi Steve,
Long time no see. I hope your well and also your Dad [Old Codger].
Ref your last to Paul about small breather hole on blade. Will bluetack do the same job?.
Phil.
Blue-tak will do [S.Sawford]
Posted: Sun Mar 31, 2002 7:01 pm
S.Sawford replied:
Hi Phil,
Yes The old man is fine.
He will be joining me at SS Marine full time next week.
and i`m now training for the sprint nationals.
Leaky Rudders [Dartful Codger 3]
Posted: Sun May 19, 2002 7:59 pm
Dartful Codger 3 replied:
Hi guys Sequel to message 1074 of March 17th
After sailing on only three occasions with the new boat - Marconi TT and 2 Sundays at Beaver, with 1 rudder blade consistently taking on approx 1/4 pint of water , whilst the other took hardly any, I decided to ask the Laser Centre to replace it .
While initially commenting that several Dart 18 sailors said this was fairly normal (although to what degree I cannot comment ), it is certainly not normal when 1 takes on far more than the other. In fact when I deliberately filled it up to check it, I found that it was leaking profusely from the back of the blade for about half it's length, and therefore coming in at a great rate of knots when out sailing .
Nevertheless, I have now received a new replacement which I put to good use at Rutland this weekend , and am very pleased with it, and the eventual service the Laser Centre gave me, courtesy of Rob Gutteridge .
All's well that ends well I say .
Paul Smith 1961
