Water at the mark [Erling]
Posted: Fri Apr 19, 2002 5:55 pm
Erling wrote:
After last weekend's discussion on water at the mark I believe Rule 18 says Room is Room for an inside boat to round or pass a mark. Does not apply at a starting mark or between boat's on opposite tacks but does apply at the windward mark
Room at the mark-or not ! [Dartful Codger 3]
Posted: Tue Apr 23, 2002 9:56 pm
Dartful Codger 3 replied:
Following the discussion on racing rules at Marconi, it was clear that Erling had a different interpretation regarding Rule 18 , so I decided I would try to clarify it for him , with the result that when I re-read the rule in my 1997-2000 edition of Rules in Practice , I remember I initially formed the same opinion as Erling . Thoughts of - 'I used to be indecisive, but now I'm not so sure' then came to mind, so I then thought it would be better to throw it open to all of you, to invite your own input on this particular situation :-
QUESTION - When 2 boats are overlapped on the same tack, and sailing towards a windward mark on a parallel course, can the WINDWARD boat claim room by the time they enter the 2 boat length zone from the buoy (which lies to windward of the windward boat and requiring a tack to round it) - got it ?
MY current answer is that the windward boat can NOT claim room, the mark being irrelevant, so it is simply a case of 'windward boat keep clear' .
The interpretation of the rule in question about this situation I believe is in 18.1 (b) and 18.2 (a) .
So there you have it - I've laid my head on the guillotine - WHO DARES NEXT to offer their version .
Please give full explanation with specific reference to the rule/rules in question. Don't burn too much midnight oil!
Should provoke some head scratching I would have thought !
Paul Smith (Beaver S.C)
RRS2001-2004 [Jonathan]
Posted: Wed Apr 24, 2002 5:58 am
Jonathan replied:
Hi Paul,
I'll just add that the rule 18.2 has been rewritten in the RRS 2001-2004 (which you can download for free from
www.isaf.org by the way), oh and I'd add for anyone new to Dart 15 sailing that this is the first time I can remember rules being discussed here - we're not normally a "rule book" fleet! (otherwise Paul would have had the current version
18.2 Giving Room; Keeping Clear
(a) OVERLAPPED ? BASIC RULE
When boats are overlapped the outside boat shall give the inside boat room to round or pass the mark or obstruction, and if the inside boat has right of way the outside boat shall also keep clear. Other parts of rule 18 contain exceptions to this rule.
(b) OVERLAPPED AT THE ZONE
If boats were overlapped before either of them reached the two-length zone and the overlap is broken after one of them has reached it, the boat that was on the outside shall continue to give the other boat room. If the outside boat becomes clear astern or overlapped inside the other boat, she
is not entitled to room and shall keep clear.
(c) NOT OVERLAPPED AT THE ZONE
If a boat is clear ahead at the time she reaches the two-length zone, the boat clear astern shall thereafter keep clear. If the boat clear astern becomes overlapped outside the other boat she shall also give the inside boat room. If the boat clear astern becomes overlapped inside the other
boat she is not entitled to room. If the boat that was clear ahead passes head to wind, rule 18.2(c) no longer applies.
(d) CHANGING COURSE TO ROUND OR PASS
When rule 18 applies between two boats and the right-of-way boat is changing course to round or pass a mark, rule 16 does not apply between her and the other boat.
(e) OVERLAP RIGHTS
If there is reasonable doubt that a boat obtained or broke an overlap in time, it shall be presumed that she did not. If the outside boat is unable to give room when an overlap begins, rules 18.2(a) and 18.2(b) do not apply.
Room at the Mark or Not [Martin]
Posted: Wed Apr 24, 2002 8:59 pm
Martin replied:
Rule 18.1b would seem to apply when boats are on opposite tacks. In the situation you describe the boats are on the same tack.
The preamble to Rule 18 says "room is room for an inside boat to round or pass between an outside boat and a mark and obstruction including room to tack or gybe when either is a normal part of the manoeuvre.
If I was the windward boat in the situation you described, I would rather hope to be given water. Hope I haven't muddied the waters too much!!
Rules Debate (or try not to be at the windward mark at the s
Posted: Thu Apr 25, 2002 4:40 am
The new rules remain essentially the same as the old rules in this regard and the net result is it is as if the windward mark was not there so port gives way to starboard and windward boat keeps clear.
The key section is 18.1b
"It (rule 18) does not apply:
b) between boats on opposite tacks when they are on a beat to windward OR when the proper course for one of them is to pass the mark or or obstruction is to tack."
Thus the opposite tacks bit is clear.
If two boats are on the same tack heading for a windward mark they are BOTH going to have to tack at the windward mark and so the rule does not apply. Thus if the leeward boat can point up and pass close to the mark he effectively can force the windward boat into the mark whether there is an overlap or not.
Addition [Bob]
Posted: Thu Apr 25, 2002 4:46 am
My heading got cut off by Jonathan's super swift software (It's now much quicker to add new chat items folks - did you notice?**).
The heading should have read " or try not to be at the windward mark at the same time as Erling or Martin"
** the software is much quicker, but these technical questions need research to answer.
Disagree on 18.1b [Jonathan]
Posted: Thu Apr 25, 2002 6:23 am
Jonathan replied:
Hi Bob,
OK, I'll stick my head above the parapet! I disagree with your reading of 18.1b, as you have conveniently left the comma out in your quote! Here's a cut+paste from the RRS2001-2004 pdf file:
(b) between boats on opposite tacks, either on a beat to windward or when the proper course for one or both of them to round or pass the mark or obstruction is to tack.
I think that comma after "opposite tacks" takes precidence over the the "or" later. Which I think completely changes the interpretation and means 18.1b does not apply to this argument!
Cheers,
Jonathan
So... [Jonathan]
Posted: Thu Apr 25, 2002 6:38 am
Jonathan replied:
After we discard 18.1b from the argument, we end up with 18.2, specifically the first 2 sections:
18.2(b) tells us that if the boats were overlapped BEFORE the 2-length zone, then even if that overlap is broken after entering the zone, the "boat that was on the outside shall continue to give the other boat room."
Which I think is pretty clear, and I'm glad we use inflatable buoys, so that those of us who would have expected to get water won't do too much damage as we hit the mark because you didn't get out of the way!
Cheers,
Jonathan
Water at the mark [erling]
Posted: Thu Apr 25, 2002 3:31 pm
erling replied:
I will use Jonathan at the protest as he reads the same book as me. Anyway I blame Nick for all this as it dident seem to matter that we sailed under different rules till the teach in.
Rounding and passing marks [Phil]
Posted: Fri Apr 26, 2002 4:25 pm
Phil replied:
I go along with Erling and Martin.
Rule 18 General:Room is room for an inside boat to round or pass between an outside boat and a mark, which includes room to tack or gybe when either is a normal part of the manoevure.
18.1 As above,but does not apply at a starting mark or when boats are on opposite tacks.
18.2 Giving room; Keeping clear.
Room at the Top/Mind the Gap/Watership Please etc. [Dartful
Posted: Fri Apr 26, 2002 7:42 pm
Story so far in this continuing saga.
Referring to message 1157 regarding rights at the windward mark, 4 people now think you can claim water , with myself and Bob still holding bets that you can't .
Far from accepting that we are the only 2 soldiers out of step, I further encourage more of you to add your opinion, particularly the 'allegedly' more knowledgeable and experienced - we know who you are ,so stand up and be counted!
This is an important rule which needs clarification, as it is a situation which often occurs, and could lead to needless claims for subsequent damage as a result - insurers please note !
Yes, it is true we are a very friendly racing fleet, with an almost non-existent record of protests , both at open meetings and National events , but I do feel this is one rule that needs clarification for the benefit of all, and it comes as no surprise to me that there is a discrepancy of interpretation so far .
I therefore hope that more of you will add your input to the continuing debate , and I will review it again in a week's time.
In the meantime - happy thinking and happy sailing .
Water at the Mark [Martin]
Posted: Sat Apr 27, 2002 4:23 am
Martin replied:
If Dartful Codger et al still have doubts, my advice would be to speak or write to the RYA for clarification. I have done this on a couple of occasions where we have been unsure on Rules matters at our Club and have always found them to be most helpful.
Having read the debate so far, my view has not changed. I would expect an outside boat on the same tack as me to give me sufficient water at a windward mark to allow me to pass, round and if necessary tack.
Bob throws in the towel - Erling is right! [Bob]
Posted: Sat Apr 27, 2002 5:00 pm
I've looked it up in my pristeen, hardly opened, version of the Bryan Willis book which explains the rules (2001-2004). The inside boat on the same tack heading to round the windward mark can claim water provided the overlap was established before 2 boat lengths from the mark. There are lots of illustrations to support it.
Well there you go. I've been getting away with it all these years.
Quod erat demonstrandum [Dartful Codger 3]
Posted: Fri May 03, 2002 5:22 pm
Well, after a week's opportunity for further volunteers to stick their neck out and cast their own personal interpretation of the current rules regarding WATER AT THE WINDWARD MARK (with no more brave takers!), it would appear that Bob's declaration with reference to the latest 2001-2004 rules book by Bryan Willis is accepted and understood. The answer to my original question 'ROOM AT THE MARK-OR NOT' asked on 23rd April therefore being that YOU CAN CLAIM WATER in the situation described .
I must say that I was persuaded some time ago whilst racing, by various 'knowledgeable pro's' who shall remain nameless, that this was not the case, and have abided with it ever since, in spite of trying to accurately decipher for myself the explanations in my 1997-2000 edition of the same rule book. However, it would appear that clearer explanations have now been added to the latest edition to remove any confusion, and irrefutably confirm that water must be given in the circumstances .
Please therefore let this message filter through the fleet, so that no more un-nautical words are cast when you next find yourself in this situation, thereby promoting the cameraderie, and enabling Tim to keep our premiums down ! Bon voyages to you all !
Paul Smith (Beaver S.C) 1961
