Batten problems [Kevin N.Wales]
Posted: Tue Jun 04, 2002 6:03 pm
Kevin N.Wales wrote:
Had a good blast today in a steady force 4-5, but I noticed that the second batten up the sail had snapped just as it leaves the plastic batten protector, on the luff of the sail. I carried on sailing for a bit, but once ashore I took the batten out of the pocket. It had de-laminated about an inch from the end. I removed the broken bits from the protector via a tear accross the pocket caused by the sharp end of the batten.
Question
1.Is the batten nackered, could I repair it with polyester resin and glassfibre tape?
2.Should I get the batten pocket repaired by a pro, or is sail repair tape worth trying till the end of the season?
Question
