Oldest Dart Going? / Rudders filling up! [Simon Liston]
Posted: Tue Aug 13, 2002 1:18 pm
Simon Liston wrote:
Hi,
Just got a Dart 15 - #55 in the sail, #55 on each rudder so I guess it's #55 ! (Was once at Herne Bay SC). Is this one of the oldest about?
It seems to be in very good condition. Few small holes in the tramp, few small dings in the rudders but that's about it.
Sailed it for the first time at the weekend (off Mersea Island where I live) - I noticed when packing up that the rudders had taken up a fair bit of water. I don't think the dings are deep enough to have made a hole but there is a small (maybe 2mm) hole at the top of each rudder. Is this normal? Should I plug them?
Have applied to join your association and would be happy to hear from anyone that's just starting out on a DART 15 like me.
Kind Regards,
Simon.
Dodgy Rudders [Dartful Codger 3]
Posted: Tue Aug 13, 2002 3:40 pm
Dartful Codger 3 replied:
Hi Simon
Regarding your rudders, it would be advisable to repair the 'dings' a.s.a.p , especially if the matting is showing underneath - it's very quick and easy to do with a gelcoat repair kit .
Regarding the holes, under no circumstances should you fill these in permanently, as they act as a breather to the cavity within the blade, and it is possible that the two halves can blow apart otherwise, if subjected to high temperatures, i.e. left out in the sun for instance .
It is quite normal for the blade to take on some water (say a couple of egg-cups full) after a couple of hours of sea sailing, but if you are getting more than that in, then it is likely that an edge has opened up slightly, or one of your 'dings' is probably a 'dong' !!
What some of us do is to push 'blue-tac' into the breather hole , which stops the water getting in, but will be forced back out if the pressure inside builds up too much, and so acts as a safety valve.
Perhaps one more tip I can offer, since your boat is of the 'vintage variety' - check the small rubber pad fixed inside the 'vee' of the aluminium casing (there should be one) which cushions the blade when you lock it down . If it is worn or missing, it is likely that minor damage will occur on the front edge of the blade at the top, which would then be another potential source for ingress of water.
Hope that helps, so happy sailing .
Paul Smith 1961 ( Beaver S.C )
Check the hulls for water [George Stephen]
Posted: Tue Aug 13, 2002 4:52 pm
George Stephen replied:
Simon,
You should also check whether the hulls are allowing water to enter. Do this with the bows tipped so high that all water in the main part of the hull (the storage chambers under the bigger hatches should be completely separate) will run to the very back, ie the grounded points should be the transoms, or possibly both the transoms and the skegs, but not just the skegs. You get the cat in this position by having the trolley well back from the main beam, perhaps behind the point of balance. Open and look through the small hatches behind the rear beam.
If there's no water, all well and good, but check each time you sail. If there is some, sponge it out or the salt will gradually permeate the buoyancy foam and add permanently to the weight. If there seems to be quite a bit, check that you don't need new ring seals for the hatches. Otherwise it seems most likely that water is leaking in round the pintle screws - some undoing and application of sealer seems to be the cure - search the Chat items using the serach facility for more detailed advice. Even if there seems to be a lot of water, immediate repair is desirable rather than essential.
If it's not leaking round the pintles, check the keel line and hull to top joints for possible leakage "points".
I think joining your local sailing club might also be a good idea - there's a list on this site and if this doesn't help you then consider searching the RYA site - rya.org.
Good sailing
Dodgy Rudders / Old Dart [Simon]
Posted: Wed Aug 14, 2002 8:29 am
Simon replied:
Thanks for the comments guys - I have a tube of 'Dr Ding' ready to put to work. The blue-tack 'plug' idea is a good one!
I'll also give the hulls another check - I certainly didn't hear any water sloshing about when lifting the hulls onto the car etc. The hatches seem to have aged a bit (the plastic is probably quite brittle) and I would guess the 'O' rings aren't quite as supple and flexible as they once were (I have a lot in common with them!) so I'll check them aswell.
It's the Round The Island Race on the 21st so I'll make sure everything is ship (or indeed Dart) shape before then.
Thanks again.
Simon.
