Cover Postscript [Martin]
Posted: Sat Dec 09, 2006 6:29 pm
Martin wrote:
Thanks for the advice guys. Windsport cover is not sitting on the boat and first impressions are excellent!
One question though. What is the thinking behind having a neck for the mainsheet? What is the advantage of having the mainsheet attached (presumably to the halyard)? It doesn't seem to support the cover so I haven't bothered and have just attached halyard to centre eyelet and tied off.
Posted: Tue Dec 19, 2006 9:03 pm
by Brian Phipps
Hi Martin, the neck at the back of the cover is so you can hang the mainshet system from the halyard if you want to , may be overnight at a regatta, it holds the halyard away from the mast. You can then run a light line from thehang point on the cover up through the halyard ring to hold the cover up.
You will aslo see you can fit the cover on with the rudders still attached , again if you leave the boat like that or when at a openmeeting.
Hope that helps.
Posted: Tue Dec 19, 2006 9:04 pm
by Brian Phipps
Hope that helps.
