dry suit seals
Posted: Wed Jan 16, 2008 9:21 pm
by darth vader
this is the best site for this kind of info
is it easy to replace seals on a drysuit of is it best to send it away to be done
any one had any experiance of this
Drysuit Advice
Posted: Wed Jan 16, 2008 10:25 pm
by Steve Willis
If you search the forum using the above heading you should find a series of responses to the same question from August 24th last year - on page 4 at present.
I have done mine twice in 11 years, bit fiddly but no problem. I thing it works out at about £35-£40 to do all five seals.
I had trouble finding the seals the second time but found dive shops sell them - check out internet shops (there are a couple of sizes so you need to choose based on your existing ones and you will need to cut the neck around one of a series of rings to get it so it goes over your head but still seals at the neck comfortably
Now is the time to do it!!!
Best wishes
Stormsure
Posted: Wed Jan 16, 2008 10:32 pm
by Steve Willis
Just remembered last autumn I bought some wet suit flexible repair filler and iron on seal tape for dry suit seals from Robert Altham at Stormsure.com
He does all that sort of thing by internet shop - Robert was very helpful in replying to e-mails. His price come to a bit more than I paid several years ago - check his web site.
Hope that is of use
Posted: Thu Jan 17, 2008 6:20 pm
by darth vader
cheers I'll give it a go
