Water in hulls
Posted: Sun Aug 03, 2008 7:35 pm
by Andrew Hannah
Are hulls designed to leak? I invariably have half a spongefull of water in each hull after racing. I don't seem to have any more if it has been blowing hard.
Would the hulls of a new boat similarly leak, or would they be bone dry?
Posted: Mon Aug 04, 2008 9:14 am
by Keith Ball
Hi Andrew,
Mine's dry (Year 2000 boat) unless I forget to secure a hatch cover properly. Check your O rings are OK & seated correctly.
However, I fear you've opened some wounds re. your question as I know some owners who would welcome your "half a spongefull"!
See you at the Nationals.
Keith
Re: Water in hulls
Posted: Mon Aug 04, 2008 2:35 pm
by Martin Searle
Andrew Hannah wrote:Are hulls designed to leak? I invariably have half a spongefull of water in each hull after racing. I don't seem to have any more if it has been blowing hard.
Half a spongeful!
blimey if only before the recent refurbishment my hulls would have several litres of water in and in the worst case the whole hull was full of water but that was a full on hole so bad example but the symptom was that I was getting more and more water in that hull until all of a sudden it failed completely.
But in normal operation it was always several litres and that is with O rings and hatch covers fully sealed.
However after the refurb I capsized in big seas which had seen the enitre boat underwater a few times prior and I had NO water whatsoever in the hulls when I returned ashore. So probably some water can get in through all those dings and scrapes in the gel coat we all get as well.
water in hull
Posted: Mon Aug 04, 2008 3:52 pm
by Brian Phipps
The hulls do have a breather hole and that is in the rear beam, drilled up into the beam casting, approx 6mm. With the hull pumping as it goes through the water it will breath through this hole and suck any water around in. The hull does need to beath so it can react to hot and cold conditins. Some people fill this hole and drill a hole in the top of the hatch cover, which is fine but the hull should have the ability to breath some where!
If you need to check a hull for leaking use a hair dryer through the rear hatch , NOt too much air and then go around with soppy water, for sure you will find the leak.
Hope that helps,
Brian Windsport. catparts.
Posted: Mon Aug 04, 2008 7:44 pm
by Andrew Hannah
Thanks Brian (and Martin).
My pals at Thorpe Bay tell me there's a breathing hole somewhere, but none knows where it is! I'm much happier knowing a spongeful of water is acceptable.
Martin: do you now use your hatches to store your digestives?
