Discoloured shrouds
Posted: Mon Dec 08, 2008 12:02 pm
by Jaycb
When I took the mast down for the winter a couple of months ago I had a quick look at the rigging before I coiled it up and put it away. Most of it's new this year anyway and I didn't see anything that looked worn or broken. However, I did notice that the shrouds (new this year, which are the plastic-coated type) had a dusty coating of rust. This could be rubbed off using a finger to reveal healthy, "silver" steel underneath. None of the other rigging had this. I'm not sure what grade of steel is used for these shrouds, so the question is...
is this normal? (for a boat kept all summer next to the sea) Or should I replace?
Posted: Mon Dec 08, 2008 5:49 pm
by Steve Sawford
Hi Jaycb
Did you have the shrouds from me ? SSMarine / speedy sports.
I have always used the best 316 bright marine grade stainless steel (A4) wire from Ormiston UK and this should not rust .
The cheaper grade (A2) stainless steel can form surface corrosion in salty conditions but should not weaken the structure of the wire rope.
Steve Sawford
shroud colour!
Posted: Mon Dec 08, 2008 7:37 pm
by Brian Phipps
Shrouds supplied by Windsport are plastic coated, to prevent any of the oil used to make the wire from getting on the mainsails and leaving a shroud line mark. The plastic also retains the oil within the wire that helps protect and lubricate it. If you have plastic covered shroud wires you should not get any discolouration from the wire itself , although it could come from else where.
Windsport catparts
Posted: Fri Dec 12, 2008 1:03 pm
by Jaycb
Steve, Brian,
I can't remember which of you it was I bought them from, I'll see if I can find a receipt. If I get time I'll take a photo and post a link to show you what I mean.
