Setting "fair" courses
Posted: Sun Feb 28, 2010 10:16 pm
by RobBowen
Looking back on some previous posts, it is obviously realtively easy to set a course that really benefits certain types of boats, but does anyone have any experience of setting courses that gives equal opportunity to most?
Obviously wind strength is a huge factor, but it seems that I guess in a force 3-4 neither cats or monohulls are hugely disadvantaged by the strength of the wind, so maybe that could be a starting point...
Rob
Posted: Mon Mar 01, 2010 10:33 am
by Andrew Hannah
It's the downwind leg, that's the problem. Boats with traditional symmetrical spinnakers prefer downwind legs that are 180 degress from the upwind leg. Curiously, boats with asymmetric spinnakers also like legs that are dead down wind. Not because they sail directly downwind, but for tactical reaching.
At Thorpe Bay, we noticed that we didn't have large numbers of asymmetric dinghies. But we had asymmetric cats who were always moaning about the square cat courses (mostly for Sprints). So the club combined asym dinghies and cats and set them upwind-downwind courses. They were not amused.
Some Hurricanes have spinnakers and some don't. So it meant the Hurricane fleet was split. It just shows how money can ruin a class. The SX kit costs about £2000, which is often more than the boat is worth.
When it's my turn to do race officer, I take a look at the number of entries in each group. Generally, the biggest group is singlehanded dinghies (Lasers, Solos, Finns) and Sprints. All these boats prefer tight reaches, as do our Albacores. So, a shortish beat with a long reach to a wing mark and back, is a good course. In other words, a wedge-shaped triangle.
The asymmetrics have their upwind-downwind courses. Back and forth they go. They get dizzy and lose count of the rounds. The asymmeric cats are moaning once again. This time, it's because they miss lapping slower boats. They can't show off anymore. And when people stop looking at them, they lose interest. You can't win!
Posted: Mon Mar 01, 2010 1:07 pm
by Martin Searle
Wind strength is definately a factor and in light winds (f1-2) dinghies are generally faster than cats, I've beaten 15's and 18's on the water in my laser on such days.
I tend to set relatively short courses when doing my race officer duties at Seasalter since they give the punters more tactical sailing. Huge courses tend to lead too processions after the first lap or so.
For cats I tend to set square courses so there are two reaches and 1 upwind and 1 downwind. Although we use a variety sometimes using the traingle with\without sausage legs sometimes using a vaguely p shaped course. Dinghies in general prefer a long run since the spinaker boats can use their kites so effectively a triangle. I suspect for a combined dinghy and cat handicap fleet a P course maybe worth a shot.
"Fair Courses" for handicap racing
Posted: Mon Mar 01, 2010 2:10 pm
by George Stephen
At Queen Mary the summer Wednesday Evening Series is open to all classes, including foiling Moths and occasionally some boards, as well as the usual run of Lasers, symmetric and asymmetric dinghies and keelboats. When I'm ok or when David Casale (and rarely Gordon and Keith Chidwick) have the time there are one or two cats. There is rarely less than 30 boats, and often more than 50.
Because it is the only series in which all classes can participate, it is the "Blue Riband" Series.
Queen Mary recognises that no one course is fair for all classes. So we sail a regular set pattern of 4 courses over the series : Windward-Leeward, Triangles, Trapzoid and Inverted P. This kind-of spreads the good and bad courses around. Each race is run on the average time per lap basis and lasts for around an hour (shorter at the start and end of the series when daylight hours are shorter).
Previously the choice of course (from the 4) was left to the RO, but this resulted in an uneven spread. The move to the regular set pattern has helped, but there remains the question of the reaching angles - this is left to the RO and there's always some kind of boat that gains or loses out depending on the RO's choice. I always hope for a tight reach, but I think that the wind speed is probably more important to me - I gain hugely when the wind is 4/5 and lose horribly when it's lower - which is all too often the case at Queen Mary on a summer evening.
But the system is probably as good as you can get for making a series "fair" for a wide range of handicap boats.
If there is angst at your Club over ROs' choice of course, maybe this approach would help?
Posted: Thu Mar 04, 2010 8:51 pm
by Charles
At Halifax we now give the points to the helm & not the boat / sail configuration. This allows light laser sailors to benefit by being able to use the right rig for the wind. Obviously it tends to disadvantage the heavy sailors who can't loose blubber at the drop of wind!
It does also help with Martin's scenario where a sailor can choose to sail a mono in winds less then F3 & cat in more than F3. I find F3 is about the turning point for performance & I too have been beaten on the water by lasers in my cat & vice versa as the winds have changed.
With regards to courses our small water results in mostly cats-cradle type courses, with shorter upwind/downwind legs & longer reaches.
