Batten end adjusters.
Posted: Thu Mar 25, 2010 9:16 am
by Jaycb
I took my old sail to a sailmaker last night with the intention of asking him to make me a copy of it. However, after unrolling it and giving it a look over he proclaimed it to be be in "very good nick" for its age, and that with some re-stitching, re-cringling, a patch and new battens it would be fine.
I'm quite surprised at this as I'd assumed it was a bin job, but of course it's very welcome news. Interestingly, he also said that the particular cloth used is actually stronger than the modern stuff and stands up better to UV (it's one of the multi-coloured panel ones from the eighties).
Anyway, I need to get a new set of battens so my two questions are:
a) Are these new fibrefoam battens I've read about now available? If so are they recommended?
b) Assuming I buy the original ones, could someone explain how the litlle white plastic adjusters that Brian sells work please? It says on his website that you need to trim the batten slightly (no problem) but I'm curious what they actually do - it isn't clear from the small photograph.
Thanks.
Posted: Thu Mar 25, 2010 2:11 pm
by Martin Searle
Hi Jaycb,
The batten end adjusters replace the little reef knots you have to put in on the pieces of string that apply tension to the battens instead the cams on the adjuster hold the string and thus its easier to adjust batten tension to the windstrength (I have them but invariably skip the adjusting bit :oops: ). You have to remove the current string and then re-use it with the adjuster.
The trimming of the battens is a little hit and miss I found but then I'm neither great at DIY or very precise but you need to create a rounding of the batten at the end the adjuster is on since the width of the adjuster is not the same as the batten.
I wired them up according to this article on Shanklin's website:
http://www.shanklinsailingclub.com/cont ... n_ends.php
Hope that helps,
Posted: Thu Mar 25, 2010 4:22 pm
by Jaycb
Ah, I see. I doubt I'll do much in the way of adjusting either, but they look nicer and will protect the end of the battens from scuffs and cracks I guess.
Thanks.
Posted: Thu Mar 25, 2010 5:01 pm
by Andrew Hannah
Hello Jaycb,
I met Brian Phipps at Ally Palace, where he demonstrated the new battens in the presence of Nick Dewhirst and myself. It would seem the earlier problems have been resolved, and he has new battens in stock.
Give Brian a call and he will sort you out!
Andrew.
Posted: Thu Mar 25, 2010 6:18 pm
by Jaycb
Already done it Andrew. I talked to a nice lady at lunchtime and placed an order. I think she said Brian is competing at Datchet at the moment.
Posted: Thu Mar 25, 2010 7:23 pm
by Erling
The other reasonthe adjuster's are good is that most people don't release the battens after use if they don't have the release ends and over time the battens twist.
