Jib Furler
Posted: Sun May 23, 2010 4:13 pm
by Robert
My furler seems to have lost a small pin which holds the furling line fairlead in place fore and aft and stops it rotating when the line is pulled or released. The pin appears to have been kept in place by a circlip which has slid out of its groove under the drum. Has anyone else suffered a similar problem? Is a replacement pin available? If not is it just a simple s/s pin of a particular length/diameter? Any suggestions gratefully received.
Posted: Mon May 24, 2010 9:16 am
by Martin Searle
Hi Robert,
Yes mine did that, the pin is a cotter pin and I did manage to put a replacement in although I had trouble with the circlip thingy, it had rotted and came apart, left it off don't know what its for (probably devilishly important
). Lasted a few years then I replaced the whole unit (that is another story!) after damaging the drum.
Posted: Mon May 24, 2010 12:48 pm
by Robert
Well, as our boats have similar dates of birth then I can expect the same outcome. The furler line did get twisted round under the drum last thing at Swanage so I guess that's what the cotter pin is supposed to prevent. Thanks Martin.
Posted: Mon May 24, 2010 2:48 pm
by Martin Searle
Yes the pin stops the fairlead from turning with the drum and getting it all jammed up with the string.
Posted: Sat May 29, 2010 12:45 pm
by Robert
Brian Phipps told me that the jib furler he supplies is the special strong one and it doesn't have the pin/circlip underneath. He has suggested that a 10mm safety ring can do the job of the cotter pin and you just cut off what you don't need, so I have ordered a packet from him (big spender, me) and I hope that the circlip will be OK. Thanks Brian.
Fixed it now
Posted: Tue Jun 01, 2010 6:38 pm
by Robert
The clips arrived from Brian but I found them a bit small so I had to pull out the stops and use my BRAIN (shoes and socks off). Durrr! I found a small, used, stainless split pin in my toolbox that I was too lazy to go and look in before. I squashed it and chopped a bit off the end and BINGO! Fortunately the circlip was OK so hopefully the thing will work for another 20 years.
