Mainsail luff groove
Posted: Tue Jun 08, 2010 7:34 pm
by Andrew Hannah
I have noticed that on some masts, the entry slot for the sail is a bit wide. This can result in the sail going up the mast, without the bolt rope in the groove. Inevitably, the sail has to be lowered a little, so as to get the bolt rope in.
The answer is to narrow the entry slot, perhaps by hammering it with a mallet. But it is also important not to close the groove itself.
It would seem two tools are required: one to narrow the entry slot, and one to prevent the groove closing. What tools do members use for this?
Posted: Tue Jun 08, 2010 8:52 pm
by Kevin Dutch
Andrew, a pound coin held in the slot will make it the correct width for the mainsail to go up perfectly. Just hold it where you think it needs closing then tap with a rubber mallet or something similar taking care not to damage the mast itself.
Posted: Wed Jun 09, 2010 1:14 pm
by Andrew Hannah
Thanks Kevin. That's where I've been going wrong.
Because of inflation, I've been using a five pound note!
