What makes a good mainsheet?
Posted: Thu Sep 23, 2010 6:00 pm
by Andy B
I'm in need of a new mainsheet for my Dart, are there any particular brands or sizes that work best l? Not sure if it makes a difference or not but my blocks are the original type.
Andy
Posted: Fri Sep 24, 2010 9:11 am
by Charles
Andy
I found that the 10mm fluffy didn't run very well through the original blocks, so I use 8mm shiny. It's a bit harder on the hands, but most of us use gloves most of the time anyway.
There is this new stuff (can't remember the trade name) which appears much more thinly woven & flexible (floppy!), some people like it, I haven't used it. It is more expensive, your chandler will know about it.
Posted: Fri Sep 24, 2010 11:43 am
by Kevin Dutch
I am using a mafioli mainsheet. That runs through the blocks superbly and does not hold water in the rope either. Another one that's good is sk75. But as Charles said they are a bit more expensive.
Posted: Sat Oct 02, 2010 4:45 pm
by Charles
You also have to be prepared for a concrete drysuit if you use mafioli !
