Set the jib up on 2026 today, is there any dimentions for the cleat position along the tramp track.
I have arrived at a position using the diagram in Brians "Catamaran Book",the position I arrived at was- from the inside of the rear beam to the centre hole of the mounting plate was 740mm, seemed quite a long way back, but that was where it worked to be.
I will give things a try on Wednesday evening, but in the mean time any advice would be appreciated,
Thanks in advance
Simon
