Hello,
do you have any trick to stop the main sheet from being washed away at the back of the trampoline?
My hulls leak a bit. I sponge about half a liter out in the most affected one after a couple of hours sail. How are the deck to beam socket build? Should I reef out the gel coat at the joints and replace it with silicone?
Thank you.
Cheers, Thierry, Loctudy, Brittany
