Hi, after taking 40 minutes to right my fully inverted boat (sail no 1344) I discovered that the top section was flooded. Having now looked at the mast I see that it has corrosion holes on both sides. I’m thinking that a good way to repair it will be to epoxy glue 1.5mm aluminium plates over the areas. I wonder if anyone can comment on whether araldite will be ok or suggest the best glue for the job.
Many thanks.
Peter
