Andrew Hannah wrote:
My boat is one of the old "Sparks". The main sheet blocks are made of stainless steel, with black pulleys. The standing end of the sheet is attached, with a bowline, to one side of the main block in the assembly. Under tension, the blocks have a tendency to twist, which makes sheeting-in fully rather difficult. Is this an inherent fault with the old-style assembly?
It would seem the more modern black plastic blocks with white pulleys don't have the same problem. This may be due to the fact that the standing end of the sheet is screwed to the centre of the main block, instead of to one side. However, before I rush out to buy a complete new set of blocks, please could members indicate whether I am correct in this line of thinking.
I don't think the rope is at fault, because I bought a new mainsheet rope from Steve Sawford.
With thanks for any guidance,
Andrew Hannah (1060).
