Graham Shrimpton wrote:
Hi all, got these instructions from Mr Gadget yesterday.
Mr Gadget - mast anti theft device.
As everything in the Mr gadget range this item is cheap and easy to make.
Materials
1 Eye Bolt (preferable stainless steel but a B&Q zinc plated one will do) same diameter as your mast pin, 6 or 8mm I think.
1 length of thick chain (just long enough to go round the base of the mast)
1 Padlock
Making lock
First of all you must bend out the loop in your eyebolt just enough to take the thickness of your chain, insert the centre loop of your chain through the eyebolt and squeeze up (try using a vice).
Fitting device
Turn your mast 90 Deg, insert eye bolt in hole locking mast in the 90 deg position. Wrap chain around mast and padlock ends together
That?s it
All the best
Graham
Sprint 1595
