I think I know what the response to this query will be, but here goes in any case:
I have recently had an accident with my Dart15 and the front underside of one of the hulls was hit hard. looking externally there wasn't much obvious damage apart from along the keel edge there are a number of dents most of which look fairly easy to repair.
But pressing along the side of the hull there appears to be a region near the front and near where the hull was hit that I think is now much softer than before.
Is it possible that the glass fibre has delaminated internally in this area. As I say there does not appear to be any externally visible damage to the sides of the hulls
If so is it possible for me to attempt a repair on this area. I'm prepared to attempt a fairly magor project to do this, but the soft area does seem fairly large (aprrox 300mm X 200MM).
Is it possble to do this repair without removing the deck, if not how difficult is it to remove the deck and how should the deck re-fixed to the hull after the repair is made.
I know I should take the hull to Steve Sawford, but I really haven't got the funds to get a professional to do this repair, if I don't fix it then I think I will have to just leave it.
Any advice aprreciated.
