Hi. I justed wondered what the latest is on the Batten debate. I had the misfortune to break 3 at the end of last season during a spectacular capsize. They were the older ones with the US pattent mark. Good quality and have lasted well.
I have so far bought 3 or 4 of the newer ones. One de-laminated after 3 sails and 2 have signs of de-lamination before I used them. The quality is as agreed no where near as good. I blame the manufacturing, not the supply. The obvious differance as I see it is the 'Waffle' is empty on the new versions, whereas the older ones had quite a bit of resin filling the waffle.
I am interested in the 'fibre foam' alternative, which I believe are much stronger, but as yet not 'class legal'. I believe they have very similar bend and performance. I can make do for now, but will need to replace at some stage in the near future, so a heads up as to the likely outcome would be appreciated.
John H Seasalter
