The hole / crack has been in the mast since I bought the boat, and there are smaller holes round the other side. They are where the waterproof plug is at the top. Both mast people said that it is "Electrolytic corrosion" caused by a reaction between the mast and another metal in the plug (probably steel of some sort). If this is the case, then it may not be an isolated issue on some older boats, so may be worth checking out.
The advice I was given (by 3 seperate specialists) was to rivet on an 18 inch "doubler" or sleeve over the affected area, which I made out of an old section of mast Steve Sawford gave me (thanks Steve!). The result can be seen below.
No oil painting, but hopefully it will prolong the life of my mast!
Rob 1348 Batcat (Bats sleep upside down)!
