Robin,
I think you're too used to scanning text quickly in order to get out to the pub asap! I'm talking about changing single blocks for doubles & possibly doubles for tripples; but I have the old, separate block system so it's possible for me without lengthening the overall arrangement.
George,
Thanks for the fitness advice. The reason my left shoulder doesn't fall apart completely is that I have strong muscles from many years of competitive swimming & waterpolo, which hold my shoulders together, but ache when doing so as the joint is often slightly displaced.
Your point about having the "new" style blocks & not being able to add to these is of course, quite correct. I believe this was a manufacturer's upgrade, which I am sure had it been proposed at an AGM would have been vociferously opposed by someone, such as your good self. As it is you have enjoyed the benefit of these blocks while I have continued to labour with my plane blocks which so love to capsize & jam. I could upgrade, but that would cost me £126.04 + postage, a little more than the nominal target of £50 we set ourselves...
However, if we consider upgrading the mainsheet system to an alternative system of, say, 2 tripple & 2 double Harken Carbo blocks the total cost would be (looking quickly at a random website) £147.98 + postage, a differential with the "bullet" blocks of a mere £21.94, seems worth it for an increase in purchase ratio from 7:1 to 11:1
Yes, a longer mainsheet is necessary, but I do not believe this is an issue under the current rules.
You use the phrase "...make use of any potential advantage." It is important to keep in mind that this is not a speed advantage & indeed could be a positive disadvantage when handling the additional sheet length, the ease of oversheeting & additional weight of more blocks and sheet.
I look forward to your response.
