Boat alignment
Boat alignment
As part of our club 'buddy' system we have been checking 15s on my boat table again, as we have a number of new arrivals over the last two years.
We did 6 boats in April and found one toeing in the bows by about 10-15mm (solved by packing front beam stops 3mm each side with hard nepoprene. One was toeing out (bad news) and needed packing 2mm either side on the rear beam stops). Two had con bars that were 15mm too long (rudders toeing out when looking along the underside skeg line. One had the con bar 8mm to short. These have been sorted out using the new adjustable con bar ends.
All had quite a lot of 'slop' in the beam sockets which we have resolved by slipping lengths of reservoir liner into the sockets with the tramp and footstraps undone. This liner is better than the old veneer method as it has some give to prevent scraping. In some sockets 2-3 layers were needed.
The results have been quite interesting with some of the most affected boats now dramatically improved. So much so that in a couple of races we have seen 4-5 boats crossing the finish line in a 10-20 second period with very old Sparks up there with 19xx boats.
All very encouraging as a number who were back in the fleet now have a new lease of life and races have become very challenging.
