Rudder Stock problem #2 [John]
John wrote:
Seems to be the in problem ! I've cracked the alloy casing
- the bit thats riveted to the metal triangular frame and has the little runner tracks that always fall out !!
Is the laser center the only place to get a replacement ??
Laser part number D90012
John
Pintel Casting [Bob]
Hi John,
I know of no other place to get the pintel casting assembly. You have to be careful as the Dart 15 part is different to the Dart 18 part (the vertical stainless steel post which locates the tiller bar is a different height). The number you quote is, I think the Dart 18 part number. You will have to ring up the Laser Centre to get the right part number for a Dart 15 (it's not on their web site as I recall).
Best of Luck!
Rudder stock problem [nigel coupar]
nigel coupar replied:
I have an illustrated parts breakdown of the rudder assembly complete with part numbers. If you would like a copy i will scan you a copy or Fax you a copy.
Please give details of Fax/e-mail...Regards Nigel
Rudder Stock [John]
John replied:
Thanks Nigel, that will be great.
Email johnjokeyte@hotmail.com
or fax 01234 881496
cheers
John
