Get hold of a copy of the Dart 15 Rigging manual - page 13 covers the points, but leaves out some details. There's some correspondence on this somewhere in the Chat pages, and maybe you can find someone who can email you. There's 16 A4 sides.
First point is not to do with furling, but is to do with getting the jib luff tension right - not too loose so that it will flap, lose power, be the wrong shape, and not so tight that it takes the bulk of the tension that should be taken on the forestay, and stretches the luff of the jib so that the jib develops the wrong shape.
when you have hoisted the jib, tie the bottom clew loosely - just so it won't fly up the forestay out of reach. If you haven't hoisted the main, do so. Make sure the cat is head to wind and tension up the main sheet as fully as you would when sailing. This tensions the rig, particularly the forestay. Then tie the bottom clew of the jib to the shackle on top of the furling drum, tensioning the luff so that it is adequately tight, but not so tight it is clearly taking strain that is properly the job of the forestay, and secure the clew to the forestay and wire halyard with a clove hitch. LET OFF THE MAINSHEET, and unhook it if you have yet to launch etc.
Take the furling line through the fairlead on the drum and out through the hole in the drum. Tie either a figure eight or thumb knot in the end so it won't pull through. If you've clipped the jib sheets carbine hook to the jib, unclip. Then wind the jib round and round the forestay, fairly evenly and tightly, until all the jib has been rolled up. Clip on the carbine hook, and you can then pull the jib sheets and hold the furling line under a little tension as it wraps round the drum. Take the furling line through the fairlead and cleat on the main beam.
I think it best to wind the jib round the forestay in such a way that the forestay cable laying will be twisted tighter rather than untwisted when you furl the jib.
NEVER furl the jib with any tension in the forestay - the tension will increase the strain on the forestay and on the short strop between the top swivel and the hounds fitting, and lots of Dart 15ers will tell you it leads to premature failure of the strop or the forestay, usually when sailing in a bit of a blow. New boats have carried a warning sticker on the main beam, but it tends to wear away/off.
Of course, if you have attached the furling line before you attach the jib, you rotate the forestay until the furling drum is full of furling line - make sure the line lies neatly in the drum when you do this. You keep the drum furled while you raise the jib and tension up the luff as above, clip on the carbine hook. When you take the furling line through the fairlead on the main beam you can pull on it and watch the jib furl.
