3 figure sail numbers [Charles Watson]
Charles Watson wrote:
I'm looking for a Dart (still!) & have seen a couple advertised with 3 figure sail numbers. How can I tell their age if the owner isn't sure ?
Does the price of these oler boats float around the ?700 mark irrespective of their age ? Are these boats still reasonably competitive at club level ?
To extend the question, at average standard club level is there much difference between 500, 1200 & 1800 sail numbers if the boat has been reasonably looked after & the sail is decent ?
Old Sparks [Dartful Codger 3]
Dartful Codger 3 replied:
Hi Charles
Don't get too hung up about how old it is, it's the condition that counts. Details on age/value of D15s can be found by looking in the Buy & Sell Guide section, although it gets a bit vague pre 1987.
Regarding competitiveness, perhaps the most important thing to check on a 'Spark' is the hull condition. If it has been neglected in the past (e.g skeg damage not repaired), it may well have soaked up some water, which obviously will make it heavier, and therefore slower. If it is possible to weight the hulls, they should not be more than 33Kg each, if kept in good condition . In fact they may be less than this on old 'Sparks' since they did not have the inner storage compartment fitted. Another important part of the boat to check is the trampoline, which if left un-covered for any length of time, exposed to the elements, will start to become brittle, and be more likely to fail.
Also check the mast for kinks - it should be generally straight (1-piece or 2-piece). Standing rigging is fairly obvious to check for broken strands, also relatively cheap to replace if suspect, so don't worry too much here.
If all is well so far, then providing the sail is in good condition, there is no reason why an old boat should be any less competitive than a newer one, and should certainly be worth ?700 minimum - what else can you buy and get so much enjoyment from for that kind of money ?
The final factor on a boat's performance depends of course on the ability of the helm, so the rest is down to you !
So good luck and hope to see you on the water soon .
Paul Smith 1961 (Beaver S.C.)
Further thoughts on older boats [George Stephen]
George Stephen replied:
For boatspeed you undoubtedly need the mainsail to be in really good condition. When it starts to "flop" when you roll it up, it won't perform as well. I use the original sail for my boat at club races, but I don't beat Gordon Goldstone with it as often as I do at Travellers or Nationals.... Always slacken off batten tension after each day's sailing, or you will induce a permanent stretch in the sail along the batten pockets, changing the intended sail shape. When you next go sailing you can then fall into the habit of thinking about the amount of batten tension you are going to tie in, varying it with regard to wind strength (least tension in light and strong winds, more in 3 to 4.
Good luck in finding a boat.
You also need the cat to be "stiff", ie minimal flexing of the hulls/beams. Check for wear in the beam housings - the beams should fit tightly with imperceptible play. re-glassing the beam housings is not easy to do, as you need to ensure everything is "squared up".
The cat is essentially held together by the tramp, and you should always tighten the tramp as much as possible to maximise stiffness - if you don't, the beams will try to slop around in their housings, promoting the problem outlined above. This is particularly important if you sail often in choppy waves - eg Thames estuary, parts of the North Sea. Ultimately the tramp will stretch as it gets old, and it may not be possible to tighten it to get the stiffness you need.
You also need to ensure that the rudders hang vertically and parallel.
Otherwise I agree that a well-maintained older boat will be competitive
Sail Number & Age [Bob]
I compiled the buyers guide from my personal knowledge. The reason it is vague before 1988 is I did not own a dart 15 until then. If some owners of old Dart 15s (or Sparks) can reply to this by adding the boat year of manufacture and the sail number then if enough reply I can construct the chart back to 1978 when the boat was first launched - Yes we are 25 next year, folks!
