sprint? [Kevin Wilkinson]
Kevin Wilkinson wrote:
I am looking for an older Dart. Some have mention that they are Dart 'Sprints' what is this sprint bit please?
Dart 15 Sprint [Dartful Codger 3]
Dartful Codger 3 replied:
Hi Kevin
The 'Sprint' bit simply refers to the fact that you can sail the Dart 15 single-handed with Main & Jib plus trapeze. That means you are suspended in a harness by a wire running to the shroud attachment point near the top of the mast, thus allowing you to get your whole body weight outboard, standing straight out, but with your feet on the side deck. This obviously gives much more leverage, and allows you to use most of the power available from 2 sails with only one person aboard, improving the power-to-weight ratio and allowing you to go much faster, hence 'sprinting'.
Thus a boat advertised as a Dart15 Sprint should come with the additional wires and fittings that allow you to do this, and of course by definition must be supplied with a jib and a longer tiller extension .
Cheers Paul Smith 1961 (Beaver S.C)
