Sprint Jib Sheet Length [Charles Watson]
Charles Watson wrote:
Is there an optimum length for jib sheets when (trying) Sprinting?
Currently mine are so short that I can't even leave them attached to the jib when I put my cover on !
In the sprinting tips it is recommended to sheet in & then drop the sheet between shroud & toe loop, but I understand that removing toe loops is now accepted practice, so where does the jib sheet end up (other than wrapped round your feet)?
