George Carter replied:
Hi Andrew. The answers so far offer very good, insightful advice. I will try to add to these.
In my opinion Trapezing on a reach is hard, much harder than trapezing upwind. There are real benefits to trapezing on the tighter reaches. The benefits get less and less as the reach broadens as it is not normally heeling you are fighting, but driving of the bows downwards. This is lucky in a way as the broader the reach, the trickier it is to trapeze.
I think this is for several reasons.
Firstly because you are so far from the trapeze attachment point to the mast you can't trapeze perpendicular to the boat with straight legs like you do upwind. There is too much force pulling you forwards. You have to be either angled back with your back leg bent, which is tiring; or if you are far back enough you can put your back foot in the rear footloop to balance the pull from the wire. This means that in general you are much less stable and use up more energy and concentration just being on the wire. (I have no problem with using the footloop and use it all the time I am at the back - particularly when I think I am close to pitchpoling, it has saved me so many times! As soon as one breaks, I replace it immediately.)
Secondly the boat is moving faster, much faster than upwind, which means that the steering has much more effect and you are more easily put off balance.
Thirdly, also any waves are likely to be side on which makes the boat pitch more. It is much more difficult to trapeze on a broad reach on the sea than on a lake. The waves are a real pain when windy on the sea and are normally the reason I come in off the wire on a broad reach sometimes.
Fourthly, sail adjustment is needed more often. If you get overpowered, you need to let the sheet or the traveller off. If you point up like you would do on a beat you lose a lot of ground and you often need to point a long way to lose the power, this is more difficult from the wire. The main and jib need constant attention to be set correctly.
Getting onto the wire
If you are rounding the windward mark onto a tight reach then it is often easier to stay on the wire. In this case the jib sheet must be accessible so you can let it out correctly for the reach. I have two toe loops on each side of my boat and loop the jib sheet around the forward one. If you do not have these toe loops you have to leave the sheet dangling over the edge. You will normally need to let the traveller off too to avoid being overpowered. You are better off easing the mainsheet too at first and gradually pull it in. If you start the reach overpowered you lose a lot of ground getting the boat set up and getting back on course.
If you have gybed onto a broader reach or are rounding the windward mark onto a broad reach it is normally better to get in, set the traveller and jibsheet up then get out on the trapeze again. You can point up to get out on the wire, this will lose you ground. I would advocate this maybe at first when you are experimenting and building confidence, but if you cannot get out onto the wire in the first place at the back of the boat on a broad reach, then you will probably be better off staying in and concentrating on keeping the sails trimmed. It is more difficult to get out onto the wire at the back of the boat as your hook will need to be further off the deck due to the arc of the wire and you will need to be leaning back from the very start to counter the forward pull of the wire. It is the same basic technique to get out onto the wire on a reach, but these factors do make it more difficult.
Here are a few general tips to gain confidence trapezing in general so you can progress to reaching:
Practice trapezing upwind with the height adjustment set very low. This needs a bit more skill as you may hit a wave once in a while and it does feel less secure for some reason. This gets you flatter on the wire and means you can move back to trapeze on a reach without ending up standing on the boat when you move aft. As a minimum the triangular part of the ring should be touching the deck. When the waves are not too big then the circular part of the ring should almost be toughing the deck. This does depend on how tight your harness is too, but mine is very loose so this should be achievable.
Build your skills on the trapeze by gradually bringing your feet closer together upwind. When sailing upwind, unless it is very bumpy you should be able to have your feet together all the time. Once you can do this confidently, you will find that you are more confident when on a reach
Get grippy tape. This made a huge difference to me when I put this on my boat 3 or 4 years ago. I felt much more secure on the wire when in waves. Also if you accidentally step on the Jibsheet you don't slide over straight away!
When sailing upwind practice adjusting the jib and main traveller from the wire. This is a skill you need when sailing on a reach.
When you first practice on a reach, do it with the jib furled. I think the jib adds a lot of complication and when you are first getting confidence wriring on a reach you are better off without it.
If you are in a race and you don't feel comfortable on the wire and you think you are not in full control then STOP and get back in. Lean out for all you are worth and don't worry about it. There comes a point when discresison is the better part of valour and it is just too risky. Everybody does this at some point, myself, Robin, Laurie, Carl. Particularly as the reach is broader and the waves are bigger! I am often surprised how little benefit I get when trapezing on a very broad reach in big waves with my heart in my mouth compared to the people around me who are not!
Philosophy
Finally have fun. I think the idea of sailing with the jib and trapeze it to have a little fun and be a bit more out of control
To get a little philosophical... Looking at sporting vs sprinting I think it is a different mindset. Sailing Una-rig tends to be more tactical as you should be almost always in total control and correctly trimmed, you can really focus on the tactics and fine tuning of the sails and boat trim. Sporting, is a percentage game. Nobody is in total control all the time when it is windy, nobody is perfectly trimmed all of the time, nobody sails the perfect course, nobody gets every tack/gybe right, nobody starts perfectly every time, nobody can see all of the marks (Gurnard), nobody trapezes on every reach and everybody capsizes once in a while.
If you're not having fun or are feeling frustrated, furl the jib or come off the wire. You will often lose less than you thought.
Good Luck!
P.S. The lake is frozen here......
