I took my old sail to a sailmaker last night with the intention of asking him to make me a copy of it. However, after unrolling it and giving it a look over he proclaimed it to be be in "very good nick" for its age, and that with some re-stitching, re-cringling, a patch and new battens it would be fine.
I'm quite surprised at this as I'd assumed it was a bin job, but of course it's very welcome news. Interestingly, he also said that the particular cloth used is actually stronger than the modern stuff and stands up better to UV (it's one of the multi-coloured panel ones from the eighties).
Anyway, I need to get a new set of battens so my two questions are:
a) Are these new fibrefoam battens I've read about now available? If so are they recommended?
b) Assuming I buy the original ones, could someone explain how the litlle white plastic adjusters that Brian sells work please? It says on his website that you need to trim the batten slightly (no problem) but I'm curious what they actually do - it isn't clear from the small photograph.
Thanks.
