Sailing in light winds- any tips?
Mike Godwin
Post by Mike Godwin »
I know the obvious tip is not to bother, but even on the South Coast in sunny Seaford, we sometimes get light winds !
I have looked at the tips shown on this web site, but I still seem to struggle in keeping up anywhere close to the Dart 18's in our club . Does anyway have anything to add that works for them or perhaps an "idiots guide for beginners" yep that will be me.
The tips guide is superb, what a shame it does not have pictures or diagrams ( I will buy the first off the printer or is it computor these days !), anyway, appreciate any guidence.
mike
1531
Hi Mike
The first point could be that a bigger cat will probably do proportionately better in lighter winds that the Sprint on the basis that the Sprint is relatively under canvassed. You can tell this by the way we keep sailing in F6s & the big cats pack up.
Having said that & assuming the water is flat:-
1) Slacken battens so the air flows over the sail & it doesn't stall as easily
2) leave down haul fairly slack (a few horizontal creases in the sail)
3) don't oversheet mainsail or jib, keep the boat going at all costs so crack off a bit on the beats
4) sit well forward to get the sterns out, bottom waterline on bow well in the water
5) move your body weight as smoothly as possible
6) move your rudders as little as possible; I hold my extension down on the deck so to adjust rudders you have to oversome some friction, this helps to keep you aware of your movements.
7) try to keep concentration even though it's boring
8) try sitting on leeward side when going down wind to lift windward hull
9) use teltales, masthead burgee & bridle wind indicator to best effect
10) reduce weight (boat empty, don't eat big pies just before sailing & leave your harness ashore)
Hope this helps.
Mike Godwin
Thanks Charles, "under canvassed" I will see how many times I can use it at the bar after racing in light winds ! Although I am sure I can point to Skipper at fault, but you have given me plenty to think about, much appreciated.
You could always have a look at the DX rig if being undercanvassed is a problem...
...the DX will be on the circuit to view, so get to a TT event !
