Hi all,
Just bought # 733, and joined the fleet at Carsington...Haven't had a chance to sail her yet.
One question; the mainsheet ratchet block does not appear to be 'ratcheting'. Yes I have tried the on/off switch both ways!
Does it work like an autoratchet only when there is a load on the mainsheet, or could it be bust?
If bust is there anything I can do to fix it?
What sort of wind strength could I comfortably get away without a working ratchet?
Are they really £135 to replace?
Thanks in anticipation.
Andy Mc.
Others may have a different view, but it sounds fine as it is. I always make sure my ratchet is switched off and the block running free anyway. It is actually an anti-reverse and locks the block when it is on. If the ratchet is on you have less control on easing the mainsheet (and the sheet will quickly wear as it will be running out over a static block)
Sounds like £135 saved to me!
One tip on the mainsheet system is to put a knot in the mainsheet just below its root in the upper block, before threading it into the blocks, so if the root were to fail the knot will jam in the lower block and save half the block system going overboard.
Personally I mostly sail with the ratchet on, except in very light conditions - especially upwind. I find it gives me greater control in that I can sail for longer periods with the sheet uncleated without inadvertently letting any out and without my arms tiring. In some conditions - e.g. when its very gusty - I might spend more time with the mainsheet uncleated than cleated - which for my averagely feeble arms just isn't possible in any kind of breeze (F3 upwards) without the ratchet.
Wear on the mainsheet is a good point - the ratchet block does take its toll - but for me its a price worth paying.
Looking at an image of the Sprint 15 ratchet block online (I couldn't picture it from memory) it looks like a standard RWO switch-able ratchet block that has been 'riveted' (by the main block axle) into the stainless fitting that holds the jammer. Not sure if that stainless fitting is Dart-specific or also standard RWO. Either way is seems a shame to spend £135 replacing the whole thing if only the ratchet mechanism within the block is bust.
It might be possible to remove and replace just the ratchet block, but I don't know what tools would be needed. It might be worth a call to Brian Phipps / Windsport to explain your predicament and see if this approach is possible. Whilst I'm sure Windsport would be happy to process an order for the £135 part I'm also sure you'll still get honest advice about any alternatives.
Before that, you could try giving the block a good soak in warm soapy water. That might free up the ratchet mechanism if it has just got bunged up with salt or dirt. Failing that you could even try to work in copious amounts of WD40 with the same aim - although you might have trouble cleaning excess lubricant up so it doesn't get onto the pulley surface or your mainsheet (not good for grip).
Just my 2p.
David Ball
Marconi SC
As yet I can't be certain until I sail, whether the ratchet is working properly or not.
Duncan, I appreciate the hint about the knot below the anchorage point on the mainsheet. Now re-reading the recent 'mainsheet' thread makes sense to me. Is that a common failure then?
David, I will as you advise, take the block home and give it a good soak/washout. It has previously been sea sailed @ Filey and could be fouled by salt. It doesn't sound gritty or anything like sand but a good clean is low cost, easy maintainance to do. The unit does look as though it is fully rivetted together so don't suppose I can strip it right down. If all else fails will definately give Windsport a ring to enquire.
Told you there may be differing views! David is a far better Sprint 15 sailor than I ever will be, so best go with his advice! I don't think many of our local fleet use the ratchet, but that may be why David regularly beats us in our winter series!
Not sure about how many failures there have been in the block. I think it may have been a tip from Bob Carter that I saw once? I think there is a chance of the root failing where a narrower guage mainsheet has been fitted.
Another unconnected tip from Bob, which I have used for some years, is to put an additional cord failsafe strop alongside the short wire strop at the top of the forestay. That wire strop takes the twist when the jib is furled and unfurled and has been known to weaken and fail. The failsafe will get you home without the mast coming down.
Duncan Ford wrote:Another unconnected tip from Bob, which I have used for some years, is to put an additional cord failsafe strop alongside the short wire strop at the top of the forestay. That wire strop takes the twist when the jib is furled and unfurled and has been known to weaken and fail. The failsafe will get you home without the mast coming down.
That sounds like a no-brainer, one failsafe strop coming up...I do like the idea of a fully sorted boat, I've already upgraded the trapeze jammers to clamcleats, a decent 3:1 downhaul with fiddle block/jammer, and 3mm dyneema with ball bearing block flying jib sheets. Any other handy tips and bimbles out there?
Hi the Sprint15 ratchet block is very robust , but like all mecanical bits of equipment benifits from regular servicing. If the ratchet is not working, especially if it has not been used for a while, the ratchet claw has proberbly sized up. Suggest you spray 3in 1 or similar down the sides of the sheave and in through the switch button and then tap the sides of the cheeks firmly with a hammer. From experience that noramly releases a corroded ratchet paw.
On the question of the Dart block, it is based on a stand RWO block but with specially modified articulation of the s/s cheeks and mounting plate to ensure there is maxium grip of the sheave at all times, while the jamming cleat angle can still be rotated to the best angle.
Hope all that helps.
Windsport Sprint15 technical support
Didn't use my ratchet at Shanklin even in the 42 knot gusts, ofcourse it depends how strong you are, but I find it just isn't worth using & is more likely to tip you in.
Halifax SWC God does not deduct from our allotted life span the time spent sailing(or talking, texting, reading, posting to websites & emailing about it)
<snip>.
First time it had happened to me so its rare, cause for me that an 8mm mainsheet needs the end that goes into the terminal fattened up to 10mm to prevent it pulling through, mine being just a piece of 8mm rope didn't have it and I didn't put one in
Steve's reply details what I should have done!
Sprint 15 sailors,
The original class rope specification for the boat was 10mm dia minium 9mm. This specification ensured the rope would clamp into the mainsheet blocks without the need for any packing out. The class decided to adopt a thinner mainsheet option allowing the rope to run faster through the bolcks. When Windsport supply mainsheet of this thinner diameter we apply a whipping to the clamped end of the rope, and mark it as the area to clamp.
Whilst the puropes of thinner sheets is to allow ropes to run faster with less friction, there is a trade off, the rope is harder to hold, the ratchet friction is reduced, so the benfit only suit those who are willing to put up with the trade offs. An option is for the class to consider reverting to the original specification so all sailors are using the same thickness of sheet and there is no individual advantage in using thinner sheets.
Windsport Sprint15 technical support.
If Boat 733 still has the original mainsheet blocks the knot is of no consequence. It is only of benefit on the newer plastic moulded blocks where the rope is just held by being clamped between the 2 halves of the block. Even then I always prefer to ensure that the clamping is effective by melting the end of the rope to form a flat at the end which cannot release the rope. A knot stops you going block to block and the best mast rake (in my view) is achieved when you can just go block to block with the maximum force you can manage. Of course you must also dump the (superfluous) swivel below the lower block to save anther 30mm or so.
I'll give the ratchet block a gentle tease and some lubricant tomorrow.
The mainsheet is 10mm, so I'll follow Bob's advice on the anchorage, and dispense with the 'saver' knot for the reason he mentions. Likewise if the swivel connection is still there, that will be going. I take it mast rake/leech tension upwind is a factor in pointing ability? I'll stick with the 10mm for now and see how it goes (especially if I'm not reliant on a ratchet).
Hi Andy - just to clarify my comments really relate to the newer black plastic mainsheet blocks. If your boat still has the old stainless steel housing blocks it does not have that clamp arrangement and it still needs the swivel. The plastic blocks have a swivel built in and so the exterior swivel is not necessary.
Both arrangements are clearly shown on page 19 of the rigging manual - this is on this website in the manuals section.
Yes Bob, I have the newer plastic mainsheet blocks. I don't know whether with the age of the boat, they were the originals, or have been replaced at some stage.
Referring back to the failsafe at the wire forestay strop, it did strike me when rigging the boat for the first time that this appeared to be the weakest link in the standing rigging compared to the rest of the 4mm wires. Would there be sense in proposing/adopting this as a class rule, much the same as the Laser have specified a mast retaining line to stop the rig dropping out if you turn turtle. As a simple safety measure it does not detract from the one design nature of the boat, costs virtually zero and there is no performance gain.
