Righting line
Righting line
Managed to use the righting line which is fitted to the front beams yesterday. It worked well but I broke the bungee cord in the process.
Does anybody know how to wire it all back up again?
Re: Righting line
Tried once some years back but then ripped it all out and since use a knotted rope attached to the mast ball and kept in the tramp bag. The bungee cords deteriorate and leave the knob hanging down and banging on the hull..
Re: Righting line
I worked it out. If you see me with 3 metres of shock cord dangling from Dreadnought then I got it wrong.
Re: Righting line
This is what I did.
Re: Righting line
That looks right but I don't want to see you sailing round the course with anything dangling.
SteveR
Re: Righting line
Post by SteveR »
Robert I've got a drawing somewhere I'll try and dig it out before going to Nats. :D 8)
Loosecannon1910
& Dee S C
Re: Righting line
Hope it's not of Liam's dangly bit.
Re: Righting line
Liam wrote:This is what I did.
Not heavy enough. Add more weight.
Re: Righting line
Yep,
That looks right but why bother? The problems include:
1) it is hard (impossible) to reach if the boat is on it's side. :(
2) it is too short to right the boat if the boat is inverted. This is because you need to stand right at the back by the rudder to get the boat to turn onto it's side and the righting rope is just not long enough to reach. :?
3) the lack of pullies and high friction means it does not stow away properly after use. This leads to the problem know as " Liam's dangly bits" :wink:
It is much better to use the free end of the main halyard :D or if preferred to use a separate knotty bit of rope as described by Steve Willis. :P
Re: Righting line
I'll try to keep it all tucked in.
Robert wrote:That looks right but I don't want to see you sailing round the course with anything dangling.
SteveR
Re: Righting line
Post by SteveR »
Are you talking about your dangly bits ?????? :shock: :? :lol:
Loosecannon1910
& Dee S C
Re: Righting line
Or fit fishing hooks to the knobbly thing on the end of the dangly bits so you can make use of them while they drag in the water...........
