This subject crops up on the forum quite often but I've noticed my hulls stay nice and dry while sailing upright in any wind (a sponge full each side at most), but if I do what I did yesterday and capsize completely over, once recovered my hulls take on a fare bit of water (ten or more sponges each side)
I replaced the rear hatch mounts and covers a couple of years ago and I have good sealing rings each side. Can water still get in under the mount if the sealant has failed between mount and hull. Is it worth applying a thin bead of sealant around each mount or should I drill out all the rivets and re-apply the mounts.
I had the cat upright quickly and don't think water could get in so rapidly any other place.
Kevin
1615
