Quick release harness hooks [Nick]
Nick wrote:
I last heard the rule to introduce QRHH was under review. Does anyone know the latest on this ? and what dare would new rule apply?
Hooks [Charles]
Charles replied:
I heard the rule has been postponed until 2007 ?
But I've just looked on the Y&Y, RYA & ISAF websites & can't find anything obvious. The latter should be difinitive...
Well and truly hooked. [Mark]
Mark replied:
I heard you could use either type of hook but that if you drowned by not using the quick release type then you wern't allowed to lodge a protest.
Protest [Chris]
Chris replied:
I think that rule would become a bit redundant, unless you're two up and your crew snuffs it!
More seriously though, is it meant to be a hook that breaks off when under mass load or just breaks off when you hit the big red quick release button?
Any tips on where to buy these from for a reasonable price? Dinghy show in March? How much are these likely to cost?
Cheers, Chris.
Quick release hooks [Peter Lytton]
Peter Lytton replied:
The hook is released from the harness when you hit the big red button, or pull the release cord depending on the particular type. A spare hook carried on your person would enable you to complete the race, or sail home.
RWO and Seasure both produce quick release hooks so you can update an old harness. And probably other manufacturers also. Prices would appear to be ?50+, and it may necessitate a sailmaker fitting it if the hook plate cannot be removed from the harness without undoing stitching. Available now from good chandlers, as the saying goes. ISAF were supposed to be reviewing the different systems on the market, and coming up with an acceptable standard. Not applicable to the Sprint, but there is a system which uses a ball and socket, instead of a hook, to eliminate snagging, which nesessitated the debate. Has anyone seen/heard this report from ISAF?
Erling is your man [Bob]
Hi Chris
A number of us bought New Magic Marine Harnesses with the quick release feature at the Dinghy Show in March for ?59.95 - that was about 25% off list price and is the whole harness - not just the quick release bar. The Dinghy Show is always the cheapest place to get the seasons sailing clothes. What's more Erling has agreed to be on the stand again this year (March 06)so you could get your order in and take advantage of our Southern Rep on the committee.
Brathwaite design [nick thorpe-beeston]
nick thorpe-beeston replied:
The brathwaitght design or dongle is a ball type systemyou need a ball fitting on your wires. So it only works on modified boats.It stops the hook damageing the boat when climbing aboard.
Hooks [Chris Read]
Chris Read replied:
Hi there details of the hooks are on Shanklin Sailing Club's web site www.shanklinsailingclub.com in the hints and tips section.
Quick release harness hooks [Dave]
Dave replied:
Seen on the Osprey site:
http://www.ospreysailing.org.uk/testsit ... id=1&mnu=1
Quick Release Trapeze Harness
Update November 16th 2005
The ISAF Racing Rules Committee proposed a change to submission 147 on quick release harnesses, which will now see their mandatory introduction delayed until 2009. Committee Chairman David TILLETT (AUS) explained the change saying, 'It?s important that sailors recognize the safety issues here and it?s just as important to ensure that the right equipment is in place and an appropriate standard developed.'
Read all the article to get all posted
