Peter Cullum wrote:Thanks Bob
Do you think it would help if I could somehow get further up the boat - eg climb on the line that I've got running from mast foot to traveller? I'm thinking I might be able to get a line off the mast with a loop and hook in with the harness. Then again that might be wishful thinking...
Presuming I should stay level with the mast as well - just lean back and be patient or bounce?
Pete
Hi Pete,
Just a few extra points.
Do not bounce - the intertia is much too great for it to make much difference. It just tires you out.
You need to be in line with the mast in a fore & aft direction. It does not help going aft once the boat is on it's side.
It is basically just a simple lever system - like a seasaw with the bottom hull as the pivot. You need to get your weight (centre of gravity) as far out from the hull as possible to increase the righting moment. This means getting your body straight and horizontal - although as soon as your body starts touching the water its bouyancy reduces the righting force.
Duncan's point about making sure that the mast and hulls have no water in them is a good one. When the mast is touching the water the boats centre of gravity is on the wrong side of the pivot - so the boat is trying to turn turtle until the bouyancy of the mast stops it. Nothing happens quickly. be patient, but if after 30 second or more the mast has not approaced the horizontal and is clear of the water then the seasaw is biased the wrong way and the boat is unlikely to come up unless you can get more weight out.
Do not dispare. Even a Sprint 15 can be hard to right on a calm day. Try not to capsize in these conditions. If there is a bit more wind it is much easier. In these conditions it is helpful to point the mast into the wind. Then the wind on the trampoline helps you right the boat and once the wind catches the sail as it comes up it all happens very fast - but can easily capsize on the OTHER side if you are not quick to grab the beam (or the tramp handle) to prevent this happening. It is not a good plan in very strong wind as this is invariably the result.
The traveller rope under the tramp is a waste of time as a righting line. If you rig it like that it's uses are as something to grab on with when the boat is upside down and as something to hold if the boat is upright but you are in the water. Thus for instance you can pull yourself along under the tramp to transfer from the back to the front of the boat, if perchance you end up near the rear beam. I have never deemed it worthwhile and have always shortened my traveller (and just use half of it) and saved the weight.
The main sail halyard is quite good (long and easiliy reached) as a righting line. It can be hard on your hands due to the fact that it is thin. So if I am Sporting I tend to wind it a couple of times round the hook on my harness. I can then lean back further without too much effort or cutting in to the palms of my hands.
